| | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 24 | 1964 c-10. Removed the six and installing a 1994 350. I'd like to retain the original 3 speed column shift for now. I know its 168 teeth and came with a 10 inch clutch. Is there room to upsize (ex. bell housing clearance) and if so, any preferences on a clutch/flywheel combo that will match up to the V-8? Thanks so much! | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | V-8 trucks of that era would have had an 11" clutch and used the same bellhousing as the 6 cyl. Since you will need a different flywheel for the later engine as it has a different size bolt pattern on the mounting flange, purchase one that uses the 11" clutch. Get a clutch kit for the year of the truck with a V-8. Fred
