1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | No I’m not going to ask about the color of gray my motor should be.😉
Has anyone painted their motor with anything but “engine” paint? Does it get too hot for regular car paint? I’m only painting the block, side cover and the valve cover. Plus the timing cover and everything on the front.
I used high temp for the manifolds.
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Lots of those folks on TV paint with car paint. As usual it's all about the prep. If you really don't want to do it over use the POR system.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 |
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I've used everything from automotive acrylic enamel to cheapo rattle can on engines. It all stays on fine. From my experience, high-temp paint isn't necessary on engines.
1951 Chevy Panel Truck
