1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1267122 05/26/2018 10:14 PM
No I’m not going to ask about the color of gray my motor should be.😉
Has anyone painted their motor with anything but “engine” paint? Does it get too hot for regular car paint? I’m only painting the block, side cover and the valve cover. Plus the timing cover and everything on the front.
I used high temp for the manifolds.
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
Sir Searchalot
Sir Searchalot
Lots of those folks on TV paint with car paint. As usual it's all about the prep. If you really don't want to do it over use the POR system.
Bartamos
Good point.
I've used everything from automotive acrylic enamel to cheapo rattle can on engines. It all stays on fine. From my experience, high-temp paint isn't necessary on engines.
1951 Chevy Panel Truck
