1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Hey there. I have what I think are Dayton wheels on my 54 GMC 630. They have a split ring on them. Can I change these to some other type of wheel like something with 10 lugs? If so how do I go about doing this? Is there an adapter or something? I can't figure out to post pics but I could email pics to someone to show you exactly what I have. They have a 9.00-20 tire on them. Thanks Ron | | | | | Joined: Sep 2017 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2017 Posts: 63 | The easiest thing to do is get some 22.5 hoops for your dayton's. That is what I am going to do on my C50. They fit right on. I have seen them as cheap a $80 each in white.
BaconFarms
1948 GMC 2 Ton 1958 GMC 370-8 1965 GMC 5000 1970 Chevrolet C50
| | | | | Joined: Nov 1995 Posts: 5,721 24601 | | 24601 Joined: Nov 1995 Posts: 5,721 | Concur with Baconfarms -- That's probably a lot easier. Get some radials and you'll be good to go. Besides, Daytons just look cooler
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Are hoops the rim with no center? I've seen tractor rims like that. Does any 22.5 inch hoop fit my Daytons? And yeah I like the look of the Daytons. Just would like to avoid killing myself with the split ring setup. | | | | | Joined: May 2018 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 51 | Yes, 22.5" fit the Dayton's style 20.00, they have a"double drop". Any good tire shop can help you out.
J. F.
| | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Daytons in 22.5 are pretty common around here.
Ed
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy cff and guys, why don't you come out to my Pikanik, then you could see all the options. Go farther down the page to the BC Bolters forum and check it out. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Those are not the split rims everyone talks about. Those are Dayton hub, two, or three piece snap ring open face wheels. i wish, I had your problem. Those Dayton hub GMC's are sexy. | | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Isn't that split ring on the Daytons dangerous like the other split rings. And I'm gonna try and come out to your Pikanik 3B | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Check the sticky thread here in big bolts “Wheels and tires, what to do?” Reasonable explanations to your questions and concerns about wheels, and resources for more reading on the subject. | | | | | Joined: May 2018 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 51 | Those Dayton hub GMC's are sexy. SEXY??¿??? First time I heard the word sexy and Dayton hubs in the same paragraph..... They do look good, but sexy?........ Anyway! .... sexy??? Really?...
J. F.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | We truck guys are turned on by the darndest things sometimes!  | | |
