2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
Ran into a slight dilemma with rust pitting on the rear of '54 261 crankshaft, don't want to assemble this engine and have it leak through the rear main seal.
I remember back in the day Speedi-Sleeves were available for the front crank seal but can't seem to locate any for the rear.
Anybody have luck locating finding one of these?
Thanks, Bud
There is not a tool made that if you don't try hard enough you can't break!
1952 3100 261 T5 3.08 Gov Locker
I wanted one for my axle. I found their technical catalog online and looked up the size that i needed. I took the number to a parts supplier and they ordered it for me.
1951 1 Ton Completed
It might be something that can be used on newer engines with a one piece oil seal but on the early engines the crankshaft flange would be in the way.
Fred
Weld it up, turn it down.
RonR
1970 340 Duster
1964 CJ5
Try a SKF part number 99387. It's the right diameter (3 7/8") and covers an area on the shaft about 13/16" wide. Since the 216/235/261 cranks don't have a big rear flange for flywheel mounting, the sleeve will slip on. Secure it with RED Loctite. If you're using a rope seal, you might have lots of problems with the seal creating excessive drag on the crankshaft due to the increased diameter of the shaft with the sleeve on it.
Thanks Jerry, that's what I was looking for.
