1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
Page 8 of 20 1 2 … 6 7 8 9 10 … 19 20
24601
The official ODSS UberScroungemeister, BoToepfer, recently dropped off a couple of these for my review -- metal versions of the wood Stovebolt Engine stand -- adjustable and on castors. Pretty sweet.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Wow, any measurements to make a set of plans on this? Maybe put a build in the tech tips John.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Those look like multi-engine stands. Looks like the side uprights slide in and out to fit different width oil pan mounting points. thumbs_up
Those look great to me. Fantastic job BoToepfer!!
I tried to use the cart I built for my 250 when I was working on my 327. It just barely fit, and that was with only 3 points of contact. I was unhappy, but had to make it work.
These look like they would have been a lot better. I might have to see if I can Fab up something like it when I have the time and money for materials.
Bought a Bullseye pick and reverse curve hammer from Eastwood. This winter is a lot of body work.
Just picked up a lightly used Lincoln Electric AC225 arc welder for less than half of retail. Needed something a little heavier duty than my HandyMIg 120V welder that pops the 20A breaker when I crank it up to the highest setting. The project in mind for the new one is modifying two engine stands to build a cab rotisserie.
A "load leveler" fixture popped up in the marketplace. I got it for $25 and it is like new!
Another quality post.
Real Trucks Rattle
Did a 2 for 1. Bought a 3/8" drive, standard, stubby allen set, got the metric for free.
Well, not exactly bought, but today I got most of my cab rotisserie done. I bought two $50 engine stands and some steel rectangular tubing to make the pivot axis horizontal (was pitched up about 5 degrees) and to raise the pivot point. I also wanted caster wheels on one end, so used one pair of them to replace the fixed axle wheels on the end with the upright. I also extended the width of that end to give it a little more stability and with what was left of the 10' stick of 2x2 tubing, connected the two end pieces for the engine stands together. If I got a longer piece of 2x2, It would also work as a frame rotisserie. Used the new buzz box for the welding. I need to practice a bit, as the welds aren't the best cosmetically (ok structurally, though). I can also use the forward end of one of the engine stands and still have an engine stand (a bit taller than normal). I figured the height of the pivot axis by scribing a circle around the cab drawing in the FAM so it could turn a full 360 degrees without hitting the connecting bar.
Very nice job. I want to see pictures with a cab on it as soon as you put it in service. :-)
Picked up a used Ingersol Rand 3/8 drive air ratchet for $15 yesterday. Went to use my old (Chinese made) one a few days ago and it was rusted solid. Strange because we are not a high humidity zone and it was stored inside the shop in a tool box. Just some projects go quicker with air. 🛠
Martin,
Did you oil it regularly, and, did you have moisture/oil traps/filters in the air inlets-or-outlets of your regulator(s)?
Yup. Trouble is I used it very seldom for the past 20 years. It admittedly neglected for too long.
Fox Offline
I just tried out my new hole saw kit from Canadian Tire. Worked well until the bit chuck came loose on the guide bit. Then, as I drilled and sawed it bent the drill bit. Now I know why Cdn Tire put 4 bits in the case...
I will cut off the bent portion, re sharpen it and try that bit again.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I bought an industrial sewing machine for 100$. Never done this before. Took me 2 night to figure everything out and getting it time. Did my seat upholstery and very pleased with the end result.
J. F.
Have rarely ever needed a load tester for a battery but needed one last week....so I came home and ordered me one. Got a painted one on sale for $25 bucks which will supply my needs.....and may never use it????
Bought a Grizzly end mill. Got tired of every time a needed a small milling job done they wanted $100 and 3 weeks to do it. Now I have more in accessories than the mill but love it.
Big Bolt Forum Moderator
I bought a 3/4" impact gun (and had to buy a big hose and larger fittings to supply air to it!) I still coult not break the bolt loose I was trying to get free but, it was on my wife's car so she was fine with me buying the tools! (at least I tried!). Now I should be able to rattle off the lug nuts and anything else I need to on my big bolts!
Mike
A friend of mine used to say "if you get it hot enough you can take it off with your fingers".
Originally Posted by Santerre
I bought an industrial sewing machine for 100$..
What model did you find?
We have a few sewing machines too, and one day I'll do my own seats. In the meantime I use them for all sorts of other projects, like a leather seat on a shop stool recently.
•1952 Chevrolet 3800 pickup
---All pictures---
Bought a 2 ton Cherry Picker from the local Tractor Supply. Typical price but I can use my Farm Tax exemption to save sales tax. Lots of uses around the ranch and it will come in handy putting the 350 in the ‘62 C-10.
5 Online: Content
Bought a point file, to have around in case I need it.
Brian
1955.2 3100 Truck
Had I not looked it up, I would have thought it was a version of a pair of door window suction cups. They attached to the inside of the window, go over the door frame, and attach to the outside of the window to hold the window in place while working/removing the mechanisms.
OR a disc rotor anti vibration/silencer for turning rotors.
I used to have a couple of those. Back in my lake days! secret
24601
Mark -- What you're talking about represents actual work .... Boo.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
John, your tool represents the work after the fun though! LOL
Mike
Bought a buffing wheel for my Makita to Polish the SS inside and out window trim and the glove box. Used red Rouge and will do the headlights on my 49-3100 soon..Bill
Wait!! When does this "fun" stuff start??
Bought an eastwood TIG200 a/c d/c welder. Had a cheap china model.
I got a tool off the Matco truck that is basically a flat strap of metal, handle on one side, sharpened edge on the opposite side. It is used to go between seams of sheet metal, to be struck with a hammer, to separate spot welds.
An expensive machete?😁
I just made a deal to buy a small lathe from a friend who is moving. I don't remember the brand or model, (I haven't picked it up yet), but he and I have made parts on it before. Now I need to remember how to use it. It's all fun!
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
I think it was somewhere around $20? I probably coulda made it out of bar stock. But, I'll see a shiny penny........... ohwell
Toolman’s gotta feed his family too. Used to love it when the Snap-on and Matco trucks stopped by.🛠
I have a neighbor who is moving and selling everything off. I bought a metal lathe that is probably over a hundred years old, same model my grandfather taught me to use when I was 10. Now I have to learn to use it again. Grand dad's was run with a leather belt, this one has been converted to electric, though the pulleys are still wood. Can't wait to get to using it!
Motor lift plate and an adjustable tilt accessory for the cherry picker.
Former BMW Rider
Former BMW Rider
ZR13 OBD2 Code Reader by Zurich
My 2006 GMC Sierra 1500 pick-up had the "Service Airbag" warning light come on and after a bit of research I decided it was time to look at a code reader. The quote for having a shop read the code was about $50 and the airbag sensor retailed for $275. I had the ZR13 up and running in no time at all. The code was B0103, front airbag sensor 2 on the passenger side. I replaced the sensor with an after market sensor for a third of the price within a half an hour. No more "Service Airbag" warning light and I used the ZR13 to confirm the problem was resolved. It's a great tool at a very reasonable price! HF even honored the $189.99 price shown in their online images!!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Live data stream is extremely helpful!!
Was working on installing my Vintage Air unit. They have some really tight bends up at the condenser. I had to borrow my buddy's S-K 7/8" #42228 crows foot line wrench. Snapon and Matco were much too fat to fit in the area. Soon after, I went to eBay. Now I own one.
I bought an Eastwood TIG200 AC/DC welder.
I recently bought a new tool box. Twice as big as my trusty Craftsm(e)n boxes. BUT, I already ran out of room! and there are still tools in the old box! To kind of cure the storage problem, I obtained a side hanging box. It gives me more room for my often used tools and a place to work from.
Real Trucks Rattle
Moderated by  MNSmith
