3 members (Otto Skorzeny, Gdads51, 1 invisible), 137 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
#602343 12/18/2009 3:45 PM
Can a pto be added to an SM420 transmission that came from the factory without one or will I need to find a transmission that has one already on it. Thanks for any insight.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #602347 12/18/2009 3:54 PM
H Online: Content
There's a square or rectangular plate bolted onto the side of the case on all the SM-420's I've seen, that's where the PTO mounts. You'll need an assortments of gaskets of different thickness to adjust the backlash of the drive gear (very important from a reliability and noise standpoint), and depending on the function of the PTO you choose to use, it might be necessary to install an adapter between the case and the PTO with an idler gear in it. What sort of accessory do you intend to power?
I've been offered the lifting cylinders and framework from a later model 1-ton dump bed for cheap. I was considering converting my 3800 to a dump but I really don't think it's worth it just for the novelty. I really don't need a dump bed, just thought it might be cool. I think I'll stick to the problems I already have. Thanks for the info.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #602399 12/18/2009 8:06 PM
It's an SAE 6 bolt opening on the RH side. Unless you can find one used it could prove expensive. The good news is that there are thousands of used ones in wrecking yards still on the trucks. It's a common transmission and was used for many years.
You didn't say that the hoist came with a pump or not. If not then a better and less costly way could be a 12v-DC elctro-hydraulic unit if the cylinders are not too large in fluid capacity. Electric units generally don't like more than a couple of gallons of reservoir capacity. A gear or piston pump could cost a lot more. If you do decide to go ahead with it then send me an e-mail and a full description of the hoist and what your getting and I can advise you on exactly what you'd require and where to get it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
jfnar #602482 12/19/2009 12:59 AM
should you proceed on this till completion you'll be surprised how you ever did without one. plus you will have many new friends wave
jfnar #1267970 06/03/2018 5:13 AM
Hi There
I have two SM420 boxes in my trucks, on with PTO and one without. I'm planning to use the PTO box in my project truck and the "might be cool" thought crossed my mind. Unfortunately no pump, hoist, frame or cylinders... Soo I might blank it off or find a novel use for it. I would like to see the linkage that engages it though.
Images of my trucks (down the bottom) are at:
https://www.pinterest.com.au/calenfeorn/project-truck/
