2 members (fonz8261, TrknGMC), 226 guests, and 4 robots.
Topics128,074
Posts1,055,999
Members48,433
On the road again
On the road again
Can anyone help on the trick as to remove and replace the handles on my wing windows ( 1953)
Small roll pin runs horizontally through the handle itself, lines up on a notch on the shaft. It has to come out and then the handle slides off (that's how it is SUPPOSED to work anyway).
Mike
1951 3100 5 window
On the road again
On the road again
thanks Mike, any suggestion on how to pull that pin out....?
SMALL pin punch, either a 1/16" or a 3/32", and a SMALL hammer. It drives all the way through. And then with your last tap, it falls out and you can't find it. It's a standard design roll pin, any hardware store will have them....so get several. Get it almost all the way out and grab it with needlenose pliers and pull. (Some folks call them a Tension Pin).
Mike
1951 3100 5 window
On the road again
On the road again
Sound like a good plan......thanks Mike for your help.....
On the road again
On the road again
Got the new ones on.....now how is the best way to drive in the holding pins, they are very tight......
The pin will have to be tapped in, gently, with a hammer. May have to hold the pin with a set of needlenose to line it up and get it started. The pin does fit in the handle tight. It will take several taps cause it only drives in a shade per tap. In other words, it ain't gonna drive all the way in with one tap. Patience.
Mike
1951 3100 5 window
On the road again
On the road again
Good advise, thanks.....
On the road again
On the road again
Job is done, thanks Mike....now on to something else.....
