6 members (tesa, 55shaker, Shade Baby, Gray_Ghost, LAROKE, Wally / Montana), 120 guests, and 2 robots.
Topics128,076
Posts1,055,922
Members48,430
I am trying to replace the rear spring eye bolts and bushings (shackles are already done) and I have a question about removing the old pin. It looks like I will need to remove the step in order to either drive the pin inboard or to drive it out outboard. Has anyone done this and can tell me how they did it? Rereading the manual and I see that they say to drive out the lock bolt, and then use a slide hammer threaded into the lubrication fitting to remove the pin. And there is no way to do that without removing the step.
Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
Lee--Google 235 chevy guy--on right side of page--click on removing spring shackle--that should do it--Bill
Thanks Bill, I have seen that info before (and used it!) but I am working on the other end of the spring, and it has a different pin and bushing than the shackle end ( and just one instead of two). There is even a difference between the front springs and the rear springs pivot pins. I’ve replaced all the shackles and one of the front pivot pins and am now working on the rear pins. Lee.
On one of my vehicles I removed the bolt on the pivot end. Each side was rusted in place. I used a U joint press and they came out with some hard work.
1951 1 Ton Completed
Though all of the shackles needed replacing, especially after removing the pins and seeing the condition on the inside, I am considering leaving these alone for now. But I cannot get it to accept grease, the grease bypasses around the fitting (maybe I need a better grease gun?). I have cleaned the inside of the pin out as much as I could, but I cannot clean out the hole in the pin that allows grease to move to the space between the sleeve and the pin. I am guessing that it is plugged up with old dried out grease. Does anyone know of a way to apply a cleaner (such as jet A) under pressure to force clean it?
