3 members (Rexville48, dwreills, Gdads51), 152 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#1267696 05/31/2018 6:57 PM
The speedo on my 56 3100 doesn't work.If I disconnect the cable from the gearbox and attach the cable to a battery drill and spin the cable, the speedo will move up the scale.I think the bit that goes in the gearbox is no good, but I don't know what is called or what type I require.Any info please on how to check what I need.Cheers
Stooby #1267704 05/31/2018 8:15 PM
V
VEW Offline
V Offline
Ironically enough, it's called a speedometer gear.
Don't know what transmission you have, but here's is one on ebay:
https://www.ebay.com/itm/1955-56-1957-58-60-CHEVY-SPEEDOMETER-GEAR-in-Transmission-21Teeth-Red-With-SEAL/131645584848?fits=Year%3A1956%7CMake%3AChevrolet&hash=item1ea6b035d0:g:sTAAAOSwl9BWL3qg
They are color coded based on the number of teeth you need.
Good luck!
~ Victor
1957 3100 - moved on
