5 members (DadsFirstPickup, 1955 1 Series, Jon G, Joe H, 68ironhead), 123 guests, and 4 robots.
Topics128,078
Posts1,056,046
Members48,433
It's been a long time since I've been active on this forum, and I am in need of some help. I have seen a few posts about swapping from a manual trans to a aluminum Powerglide, and unfortunately most of those posts are from years ago. Anyway, I am doing the same swap and I am in need of the tranny bracket that mounts to the frame and links up the shifter on the PG. They have one a Brother's, but its for a '67-'72, also it isn't shaped the same, the legs are twisted, etc. (It looks like a 'U' with a guide pin in the center.) Here is a link to view a pic from an old post that was here on the forum, https://goo.gl/images/2JGAeM. I have searched the internet high and low and can't find an original. Does anyone have one of these I can purchase, or does the one from a '67-'72 work, or do I just have to break down an fab one? (I live in MI so junk yard finds are out of the question around here.) Thanks in advance, Janine
Place an ad in the Swap Meet Forum.🛠
I will soon be getting the part I needed, thanks to Tony from 4-5-6 Chevy trucks!
good luck
