2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | The speedo on my 56 3100 doesn't work.If I disconnect the cable from the gearbox and attach the cable to a battery drill and spin the cable, the speedo will move up the scale.I think the bit that goes in the gearbox is no good, but I don't know what is called or what type I require.Any info please on how to check what I need.Cheers | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Ironically enough, it's called a speedometer gear. Don't know what transmission you have, but here's is one on ebay:
https://www.ebay.com/itm/1955-56-1957-58-60-CHEVY-SPEEDOMETER-GEAR-in-Transmission-21Teeth-Red-With-SEAL/131645584848?fits=Year%3A1956%7CMake%3AChevrolet&hash=item1ea6b035d0:g:sTAAAOSwl9BWL3qg
They are color coded based on the number of teeth you need. Good luck!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | |
