1 members (klhansen), 107 guests, and 1 robot.
Topics128,062
Posts1,055,856
Members48,428
#1267594 05/30/2018 10:36 PM
Seeing a post elsewhere on the forums got me thinking. Has anyone added backup lights to an AD? Mine has the old 4 speed trans, so I don't see how a switch could be installed, but back up lights would sure be handy! Maybe a toggle switch on the dash? But awfully easy to forget and leave them on, I imagine.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Sir Searchalot
Sir Searchalot
The paddle and switch shown in Tim's 3rd link is very hard to find. Can be fabricated.
Did this to my sm420 last year and it worked great
See post - SM420 Backup Light Switch
1951/54
Basketcase
There is a toploader for sm420 in eBay right now. It is a 67 cover with a switch
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Haunting the SBP since 2001
We ad back up lamps all the time to the 30's,40's & early 50's trucks.
We use the Guide NOS 4 speed shifter paddle switches along with an assortment of era correct flush mounted or rear bumper bracket mounted lamp assemblies.
http://pic20.picturetrail.com/VOL1568/13678754/24528751/413911261.jpg
Recently saw a truck with back up lights. They were mounted to the bumper brackets. And he used motorcycle lamps. It was nice and clean installation.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
...pic...
...pic...
I use a under dash switch
DadS50, Where'd you find that. That's nice.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
I picked that one up at the Pomona swap meet
I believe its a guide b-31. The bracket came off a diffrent light
Here a pic of the switch
...pic...
...pic...
I used a red lighted toggle switch I got from Pep Boys. And the lights are LED from off ebay. I don't particulary like the way they look, (too modern) but they light up like a pair of headlights to the rear! Couldn't find any lights I liked, so I used these. I needed them right away, when I visit friends for dinner, and leave after dark, they have several dogs I have to be careful of!
capnduane, I really like those lights. On my one ton the rear bumper sits so far behind the fenders that I could mount them out to the side. And the idea of a lighted switch (to let you know they're on?) sounds really good. If you have numbers for those send them along.
Tim
Tim
https://www.ebay.com/itm/4inch-Cube-LED-Work-Light-Bar-Pod-Work-Spot-Flood-Combo-Beam-Offroad-Fog-Driving/202222772592?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D52570%26meid%3D7b7cf11ad1c54e9d9ab77cd1afa5b11b%26pid%3D100005%26rk%3D6%26rkt%3D12%26sd%3D222885316192%26itm%3D202222772592&_trksid=p2047675.c100005.m1851 I don't have a part number for the lights I used, but you can search ebay and they have many pages of backup lights. Here's a set that comes with a bracket mount like mine have. The switch I used lights up when you turn it on.
Did mine a few years ago. Switch is threaded into the SM420 so each time you put the truck in reverse, what happens? ;-)
[img]http://www.cmaynard.com/Truck/BackUpLites.JPG[/img]
Craig
I've seen a couple of trucks with two small LED pocket flashlights adapted to fit into the rolled top of the bed sides. Those things put out a lot more light than their small size suggests they can.
As Jerry said, there are lighting kits available (somewhere), but are not flashlights. I thought about using them as auxiliary lights since the "stock" lights I used were not very bright.
Another quality post.
Real Trucks Rattle
My rear turn signal lamps are now located right below the rolled tops of the bed side panels.
[url=http://www.cmaynard.com/Truck/HaulinBush.JPG]Haulin Bush [/url]
Craig
