0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | Can anyone help on the trick as to remove and replace the handles on my wing windows ( 1953) | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Small roll pin runs horizontally through the handle itself, lines up on a notch on the shaft. It has to come out and then the handle slides off (that's how it is SUPPOSED to work anyway).
Mike
1951 3100 5 window
| | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | thanks Mike, any suggestion on how to pull that pin out....? | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | SMALL pin punch, either a 1/16" or a 3/32", and a SMALL hammer. It drives all the way through. And then with your last tap, it falls out and you can't find it. It's a standard design roll pin, any hardware store will have them....so get several. Get it almost all the way out and grab it with needlenose pliers and pull. (Some folks call them a Tension Pin).
Mike
1951 3100 5 window
| | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | Sound like a good plan......thanks Mike for your help..... | | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | Got the new ones on.....now how is the best way to drive in the holding pins, they are very tight...... | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 |
The pin will have to be tapped in, gently, with a hammer. May have to hold the pin with a set of needlenose to line it up and get it started. The pin does fit in the handle tight. It will take several taps cause it only drives in a shade per tap. In other words, it ain't gonna drive all the way in with one tap. Patience.
Mike
1951 3100 5 window
| | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | | | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | Job is done, thanks Mike....now on to something else.....
