1 members (Otto Skorzeny), 95 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
I am putting together a set of original 6.00 X 16, 6 lug wheels for my 51 Chevy 1/2 ton.
I have 2 decent original wheels that have the 4-1/2 " inside width and 3 original wheels that have a 4" inside width.
The tires are 6 ply original type tires with a 4-7/16" tread width
The 4-1/2" inside wheel width are per the original specs.
My question is will the wheels with the 4" inside width work per axle or should I continue to search for more wheels with the 4-1/2" inside width?
Thanks!!
Mike
1951 Chevy 1/2 ton w/ 1959 235
1971 Chevelle
I’d look for four matching wheels.
However the real answer is what acceptable wheel widths are specified by the tire manufacturer for the tire you plan to use. If both are acceptable then you could us both, keeping a matched pair front and back.
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks for the good advice Grigg
As you suggested I just researched the tire maker specified wheel widths, which are 4" to 4-1/2" so I am compliant to use both but I may hunt for the elusive 2 wheels with the 4-1/2" widths.
Thanks again!
Mike
1971 Chevelle
After spending a fortune on blasting, epoxy priming and painting the rims for my pretty boy AD, I noticed that one of my rims was 4 inches and the other three were 4 1/2 inches. I went with the oddball anyway. I am running tubeless radials and have 1800 miles on them without any trouble at all.
There is no noticeable difference in appearance either.
Carl
