7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#1265890 05/14/2018 7:41 PM
I have a 49 3600 with an Eaton ho52 rear end. I need to replace the pinion bearings.
Are the bearings the same regardless of the gears? Are the 5:14 bearings the same size as the 4:10 bearings?
I swapped out the 5:14 and installed the 4:10 but the pinion bearings are bad. I did a practice round on the 5:14 punkin and removed the pinion. Are these bearings the same? Can I order off these?
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
' Offline
The pinion BEARING ASSEMBLY doesn't care if the ring & pinion is a 5:14 or a 4:10 .
The Pinion Bearing Assembly for your truck
was originally GM part # 609864
superseded to:
GM # 442093 in March , 1951 .
This bearing assembly is available from: Collectors Auto - phone: 800 - 414 - 4462
You will need lot's of other parts to do this repair the right way .
I have photos & part numbers of the parts you'll need .
Important note on this bearing assembly .
You will need to make sure the bearing assembly is still wired together . This is the way GM
made the assembly at the factory . GM custom fit the spacer .
The Bearing Assembly is stamped : HY 305396ZD - made in the USA . Hyatt was the ball bearing division of GM .
see PICS
https://s26.postimg.cc/j7mrbn295/Bearing_Assembly_609864_and_442093.jpg
https://s26.postimg.cc/8ksy681tl/Pinion_Bearing_Assembly2.jpg
https://s26.postimg.cc/fo0tlumop/Pinion_Bearing_Asssembly_z.jpg
https://s26.postimg.cc/8rbqtw96h/Pinion_Bearing_Assembly_u.jpg
I have a PDF file that I made . It's a copy of the Rear Axle GM repair manual that I own .
I can send it to you if you give me your email address .
https://s26.postimg.cc/9jeesyfwp/Rear_Axle_1a.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
George, I could sure use the pdf file. That you have on 3/4 ton differentials.
[email protected]
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
' Offline
SavannahDog , PDF file sent two minutes ago .
Let me know that you got it ok . It's ( 4.4 mb's ) in size .
It may take a minute or two to download depending on your connection speed .
George
1954 3600
Now cruising in
The Passing Lane
George
Thanks for the post loaded with info. I’m finally to a point where I can break it down again and make the repair.
Thanks Don
George
Please send the pdf to [email protected]
Thank again
Don
' Offline
Don , PDF file sent two minutes ago .
Need any other parts or gaskets.......I have photos I can send you .
I rebuilt my rear axle internally 100% with GM NOS parts .
It took me six months to hunt down the parts .
George
1954 3600
Now cruising in
The Passing Lane
George
I found the smaller bearing. Still looking for the rest.
Thank Don
' Offline
Don ,
The rear pinion bearing requires a new LOCK RING ( rare part ) as per
the repair manual .
manual PIC
https://s26.postimg.cc/ijfu9dylj/IMAGE10.jpg
Rear Pinion Bearing
PIC
https://s26.postimg.cc/okdj6bvgp/Rea_Pinio_Bearing_NOS_2.jpg
LOCK Ring is available GM NOS
Dan's GM Obsolete
Chinook , Montana
phone : 406 - 357 - 2615
Dan's has ( 1 ) Lock Ring in stock - GM # 370464
PIC
https://s26.postimg.cc/eab474nll/Lock_Rings_NOS.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
' Offline
You may want to consider purchasing these parts .
1.) PINION SEAL - GM # 3653618
PIC
https://s26.postimg.cc/5uq53f7k9/Pinion_Seal_NOS.jpg
Collectors Auto
Blaine , WA .
phone : 800 - 414 - 4462
Collectors has ( 3 ) in stock .
2.) PACKING - GM # 3653617
PIC
https://s26.postimg.cc/bvnu0h715/PACKING_NOS.jpg
Dan's GM Obsolete
Chinook , Montana
Dan's has ( 6 ) in stock
3.) AXLE COVER GASKET - GM # 3665606
PIC
https://s26.postimg.cc/6x0blug21/Axle_Housing_Cover_Gaskets_1.jpg
Dan's has ( 16 ) gaskets in stock .
4.) CARRIER CAP GASKET - GM # 3682147
PIC
https://s26.postimg.cc/epqzdqtq1/Differential_Cap_Gaskets_NOS_b.jpg
Dan's has ( 5 ) gaskets in stock .
5.) PINION FLANGE WASHER - GM # 3725866
PIC
https://s26.postimg.cc/pcksjcp2h/Pinion_Flange_Washer_NOS.jpg
Whisler Chevrolet
Rock Springs , WY .
phone : 307 - 362 - 5677
Whisler has ( 2 ) washers in stock
6.) PINION NUT - GM # 3650631
PIC
https://s26.postimg.cc/42x68ighl/Pinion_Nut_Rear_Axle.jpg
Dan's has ( 1 ) nut in stock
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Thanks George. That’s a very big help.
Don
' Offline
Don ,
You will need Inner Hub Axle Seals .
GM # 5.622 - GM # 3686563 superseded to : GM # 3743202
I believe the interchange part # is # 2081 for Timkin or National or Moog brands .
I'm only into GM NOS parts so I went with GM original parts .
Axle Seal
PICS
https://s26.postimg.cc/ge0p5x15l/Hub_Seals_Rear_Axle_NOS_2.jpg
https://s26.postimg.cc/4ep6yo0qh/Inner_Axle_Bearing_Seals_GM_NOS.jpg
https://s26.postimg.cc/66i5tkrt5/GM_3743202_Inner_Hub_Seal.jpg
Collectors Auto
Blaine , WA.
Collectors has ( 2 ) GM # 3743202 in stock .
Since your Pinion Bearing took a dump the other axle bearings may not be far behind .
You do not want an inner or outer axle bearing or a side differential bearing to fail as that failure
may cause some REAL damage .
The Side differential & Inner axle bearings are the same part # .
GM # 5.536 - GM # 188930 superseded to: GM # 9412415
GM # 188930 is stamped : D11786
PICS
https://s26.postimg.cc/qdvllw4q1/Axle_Bearing_from_BRUCE.jpg
https://s26.postimg.cc/b55o84ird/Axle_Bearing_Inner_B.jpg
Friesen Chevrolet
Sutton , Nebraska
phone : 402 - 773 - 5538
Friesen Chevrolet has ( 1 ) GM # 188930
Friesen Chevrolet also has ( 1 ) GM # 9412415
Collectors Auto
Blaine , WA.
Collectors Auto has ( 3 ) GM # 188930 & ( 3 ) GM # 9412415
You can also search ebay using the part # as the search criteria .
The Outer Axle Bearing is GM # 5.585 - GM # 188932 superseded to : GM # 9439835
PICS
https://s26.postimg.cc/s5okgt3ih/A_1_aaa_Outer_Axle_Bearing_NDH_NOS.jpg
https://s26.postimg.cc/90lb724a1/A_2_Axle_Bearing_Outer.jpg
GM # 188932 is stamped : B11630
Friesen Chevrolet has : ( 3 ) GM # 188932 & ( 7 ) GM # 9439835 in stock .
Colonial Motors
North Branch , NJ
phone : 908 - 722 - 2700
Colonial has : ( 3 ) GM # 9439835 in stock .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
' Offline
Don ,
In case you can't find a GM NOS pinion bearing assembly .
At least they are finally be reproduced @ Jim Carter's .
They are currently back ordered .
PIC
https://s26.postimg.cc/mk2lwd4eh/mep397.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
' Offline
Don ,
There are ( 4 ) possible different size SHIMS that are used to set the PINION DEPTH .
You will probably wind up using ( 2 ) different size shims .
They come in ( 4 ) thicknesses - .012 " / .015 " / .018 " / .021 "
example PICS of the pinion bearing shims , they come ( 2 ) shims per GM package .
https://s26.postimg.cc/b6bxqib2h/3785590.jpg
https://s26.postimg.cc/hdnbqo6tl/3785588.jpg.
See pages: 19 & 20 in the rear axle repair manual that I sent to you .
PIC of page 19
https://s26.postimg.cc/g6dzch8qh/Rear_Axle_19.jpg
PIC of page 20
https://s26.postimg.cc/4vbbnjwk9/Rear_Axle_20.jpg
These shims are getting quite scarce & are hard to find .
The Original SHIMS were:
1.) GM # 5.460 - GM # 3686523 - .012 " thick
This part # superseded to : GM # 3785588
GM # 3785588 is available GM NOS .
Friesen Chevrolet
Sutton , Nebraska
Friesen Chevrolet has ( 2 ) GM # 3785588 in stock .
Whisler Chevrolet
Rock Springs , WY .
phone: 307 - 362 - 2615
Whisler Chevrolet has ( 2 ) GM # 3785588 in stock .
_
2.) GM # 5.460 - GM # 3686524 - .015 " thick
This part # superseded to : GM # 3785589
GM # 3785589 is available GM NOS .
Friesen Chevrolet has ( 3 ) GM # 3785589 in stock .
Whisler Chevrolet has ( 4 ) GM # 3785589 in stock .
Dan's GM Obsolete
Chinook , Montana
Dan's has ( 5 ) GM # 3785589 in stock .
_
3.) GM # 5.460 - GM # 3686527 - .018 " thick
This part # superseded to : GM # 3785590
GM # 3785590 is available GM NOS .
Friesen Chevrolet has ( 8 ) GM # 3785590 in stock .
Whisler Chevrolet has ( 3 ) GM # 3785590 in stock .
Dan's has ( 4 ) GM # 3785590 in stock .
_
4.) GM # 5.460 - GM # 3686528 - .021 " thick
This part superseded to : GM # 3785591
GM # 3785591 is available GM NOS .
Friesen Chevrolet has ( 3 ) GM # 3785591 in stock .
Dan's has ( 1 ) GM # 3785591 in stock .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
' Offline
NAPA auto parts carries an after market rear axle Pinion Bearing .
It replaces , GM # 5.447 - GM # 609864 & GM # 442093 .
The price is out of this world !
PIC
https://s26.postimg.cc/41wxdbuix/NAPA_-_A_1011_Pinion_Bearing.jpg
NAPA link
https://www.napaonline.com/en/p/BRGA1011
update:
I just went to the NAPA link , they reduced the price to $503.99
update :
Bower / BCA bearing company ( a made in the USA company )
at one time made a after market pinion bearing for your truck
PIC
https://s26.postimg.cc/pal68f00p/8cc52180189e4100b32b72a88f37e947.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Thanks again George.
Don
' Offline
Don ,
I found a private seller that has ( 1 ) GM NOS pinion bearing GM # 442093 .
This part is a very hard part to find . I have my doubt's that I could find another one GM NOS .
https://s26.postimg.cc/s5u4krayh/Pinion_Bearing_GM_442093_1946_to_1960.jpg
I'm waiting for him to send me a price via email .
When I get it........I'll send it to you along with his contact info .
Don , if you don't want this part . I'll post the price & contact info right here on stovebolt .
Maybe some one else here needs this part .
Found another repro pinion bearing .
PIC
https://s26.postimg.cc/6yqdwtqmh/Motion_Industries_Timken_Pinion_Bearing.jpg
https://www.motionindustries.com/productDetail.jsp?sku=00666181
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Hi George,
How do you check inventory at Dan's GM Obsolete and when was the last time you were able to buy anything from them?
I called them to see if they had any of the carrier cap gaskets referenced above, #3682147, and the rear spring pins, #3656669, and the guy that answered the phone said all the small parts are boxed up in the basement and it's not worth their time to find them. They're only interested in selling big parts like body panels and such that they can see by glancing across the room.
Shawn
1950 3600 Pickup, 1958 Plymouth Belvedere
ShawnV, the last post is from 5 years ago.
1950 Chevrolet 3100 (Ol' Roy)
Shawn,
This is a 5 year old thread and George hasn't been on the forum for quite some time.
You might want to start a new thread with your questions.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I saw it was an old thread, just figured I'd add onto the conversation in case the search feature brings others to the topic like it did for me while looking for the part numbers listed above.
I just wanted others to be aware that one of the parts sources listed, while maybe a good source at the time, no longer seems to be the case unless you want a big, expensive part.
Shawn
1950 3600 Pickup
Shawn
