| | | Forums66 Topics128,129 Posts1,056,700 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | When I started rebuilding my 1946 1/2T truck, it had came with a rusted out 216 engine and a Carter YF manual choke carb. An acquaintance provided me with a 1955 235 engine. It came with a Rochester series B carb, automatic choke. I would much rather have the manual choke. Is it possible to use the Carter YF on my '55 235? The hole spacing on the bottom section (carb to manifold mount) doesn't quite match, so I would presumably need some sort of adapter.
Bob
BobS46
| | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | The extra displacement of the 235 will make the Carter run a little rich, due to more volume going through the carb at any particular RPM. It would be simpler to run the 216 intake manifold on the 235 with a set of stepped-up alignment rings than try to adapt the Carter to the wide-spaced 235 mounting flange. Jerry
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | first of all, I don't have the 216 manifolds any more. And I am not sure what "stepped-up alignment rings" are.
Bob
BobS46
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | There are YF carbs designed for the 235 that would have the correct base size. Check eBay
I believe model 2100s would fit your engine.
1951 3100
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Stepped up alignment rings allow the use of a 216 intake, which uses a smaller intake alignment ring then the 235, fit a 235 chevy head which has a larger intake ring and vice versa. They are nice to have when you want to install an intake that was made for a 216 on a 235 or in this case. That being said, I am pretty sure there are later YF's or YFA's with the larger bolt pattern although I don't know whether the larger YFs came with manual choke.
Mike
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
