8 members (55shaker, classicfins, 37 GC, Otto Skorzeny, Shaffer's1950, 1946chevytruck, CandoBrent, 1 invisible), 80 guests, and 3 robots.
Topics128,128
Posts1,056,661
Members48,450
1948 Chevrolet Pick-up truck 1/2 Ton. How to remove the lock & bezel for the Glove Box? I've got everything else stripped out of the cab, but cannot see how to remove this unit. Thanks!
There is a tiny clutch head screw which is hard to get to. You need a mirror to see it and you will probably need to remove the glove box to get to it.
Look to see if there is a screw on the retainer on the rear of the lock, . remove the screw and push the lock / bezel forward.....should come apart
see lock at Classic - https://www.classicparts.com/1941-53-Glove-Box-Lock-Key-W_Retainer/productinfo/22-353/#
Ron - - Dusty53
1954 Chevy 3604
Originally Posted by DADS50
to remove the lock look at jocks 1st pic.
remove the screw on the back
if your lock is original the screw may be clutch head
[quote=jockbolter50]
I hope these help anyway.
Jock.Pic # 1
Pic # 2
Ah I see it now! Thank you so much!!! This was the last piece to take out of the cab before I get it blasted.
Moderated by  ndkid275, Phak1
