2 members (2-Ton, Gdads51),
107
Mod | | | Forums66 Topics128,093 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | 1948 Chevrolet Pick-up truck 1/2 Ton. How to remove the lock & bezel for the Glove Box? I've got everything else stripped out of the cab, but cannot see how to remove this unit. Thanks! | | | | | Joined: Mar 2010 Posts: 10,290 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,290 | There is a tiny clutch head screw which is hard to get to. You need a mirror to see it and you will probably need to remove the glove box to get to it.
| | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Look to see if there is a screw on the retainer on the rear of the lock, . remove the screw and push the lock / bezel forward.....should come apart see lock at Classic - https://www.classicparts.com/1941-53-Glove-Box-Lock-Key-W_Retainer/productinfo/22-353/#
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | to remove the lock look at jocks 1st pic. remove the screw on the back if your lock is original the screw may be clutch head [quote=jockbolter50] I hope these help anyway. Jock. Pic # 1 Pic # 2 | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Ah I see it now! Thank you so much!!! This was the last piece to take out of the cab before I get it blasted. | | |
