0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#179689 09/15/2004 7:34 AM
I've had a few negative comments about my rear turn signals. In front I converted the the park lights and in the rear I used two F ord pickup marker lights on either side. I was considering putting lights in the ends of the rolls on top of the frame rails.
I was wondering if anyone has found a good supplier of such or an idea of what works well.
#179690 09/15/2004 12:39 PM
Here is a copy of an E-mail I received. Someone on this board has these LEDs in the roll. The supplier is pros-pic.com???
As follows;
Believe it or not the Led lights will work on 6 volts and they are not substantially dimmer
-----Original Message-----
Sent: Tuesday, January 13, 2004 9:20 AM
To: [email protected]
Subject: FW:
Sent: Monday, January 12, 2004 3:07 PM
Subject:
I am looking at a pair of your bed roll lights in LED. My question…My 46 Chevrolet truck is running on 6 volt. Do you have a set of bed roll lights that will work for the old 6 volt system?
#179691 09/15/2004 1:50 PM
Horvath,
A member of this site has LED lights in his bed rolls.
Here is his link to his website.
web page
Chris
Chris 1955FirstSeries
#179692 09/15/2004 2:14 PM
I have neon paint on my hands and arms, works well, then you can give a non-traffic signal if you wanna grin nice to hear from you skip...Fred
Redryder pix
My Hotrod
The led lights are available for the bed rolls but are expensive. I turned a couple of dowels on a wood lathe, a piece of closet rod would work, and drilled a hole in the center. I then fitted a pair of led marker lights from Advanced Auto in the holes' painted the wood black and ran wires down the standard pocket to the turn signal switch. I pushed the assemblies into the bed with a little black silicon for glue. They are not even noticeable when off and very bright when turning. Less than 12 bucks spent.
Wow, talk about resurrection of an old thread! 14 years, that’s gotta be a new record. Post a photo so we can see your creative idea.🛠
BTW, the only member to that discussion who is still around is Fatfenders and his last post is a year old.
An oldie, but a goodie. (The thread that is)
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
