0 members (),
135
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | The start date is getting closer so I’m spending time gathering ALL (within reason) the components I will need to complete my project. Here’s some background, 1962 Chevy C10 short stepside. Original 235 and 3 speed. Original X frame. My overall plan is V8, auto transmission, power steering, power brakes (disc front, drum rear) and A/C. I have the engine and tranny and of course the truck. My question, to those of you who have done this, can you tell me what parts, including part numbers if you can, I need to gather up? Things like motor mounts, power steering components, power brake components and drive train components. I’ll be using an aftermarket steering column and a Lokar Nostalgia shifter. Please help out a fellow Bolter with constructive advice. BTW, for those purists among us, the original I-6 and 3 speed will not go to the scrap yard. All your help is appreciated and will be archived in my build book. Thanks
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You may want to look at universal tubular cross members for motor and trans, no welding. I have used them. You need the whole front clip taken off at least. I seem to remember that disc brakes are difficult on torsion bar suspension. Power steering and brakes have many options, donor and aftermarket. Torsion bar suspension does create problems for some of that I think. Better study the internet for 60-62 swaps. Generally power steering is mounting a box and hooking up to column with universal joints. Then plumb it up. That part is straight forward. The only difficult part is pitman arm and drag link. Here are the cross members I speak of. Speedway Motors 91018212 for motor. 91628903 or 91628905 for trans. End caps 91618010
Last edited by bartamos; 05/26/2018 10:55 PM. Reason: changed from power steering to "disc brakes" are difficult...
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Thanks, that answers some questions.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Front clip meaning: sheet metal body. For access to work. Also: meant to say "disc brakes" is previous post.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | As you suggested, I did a google for the steering conversion. Lots of kits available but very pricey. Same with disc brakes. The engine/tranny crossmembers are more reasonable. Guess I’ll see how deep my pockets are. Thanks
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Maybe just do the motor. Get it driving and see how she stops and steers. Probably acceptable.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Howdy Martin I also have a 62 C-10 and the front cross member from a 73 / 80ish is almost a bolt in conversion. That will give you power steering and disc brakes. One hole to relocate on each side for cross member the other two fit. also need to remount the top attachment point for the shocks. You loose the torsion bars for coil springs but that allows you more options. The wheels will be 5 studs now, do you change the front hubs back to six or change the rear to five.
The booster and master cyl. from the donor truck can also be used. Detailed instructions can be found on this site.
Good luck and have fun. Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 |
