1 members (Guitplayer), 104 guests, and 3 robots.
Topics128,201
Posts1,057,281
Members48,467
Hello,
the pistons which were in my engine have a mark on the top. Should show this mark the rear or to the front? Or is it equal where this mark shows?
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Moderator, Electrical Bay
The last pistons I bought with a notch in the top were designed so the mark faced the front of the engine, Wolfgang. You should also see marks on the piston rings which show which side faces the top (usually a tiny o is stamped into them).
Jon
~ Jon
Rules of thumb, mark towards the front. Exception may apply!
J. F.
Ok, thank you for your answers.
Wolfgang
If you are talking about a Chevrolet 216, the original pistons did not have a front and back. After market aluminum pistons sometimes had a slot in one of the thrust faces and it was intended to go on a specific side. Somewhere around 1954, 235s had an offset wristpin and those pistons were definitely made to go in one way only.
1951 1 Ton Completed
Originally Posted by wokri
Hello,
Ask
Wolfgang
No... it is not equal where this mark shows.
Do your connecting rods have a stamped number on them?
When installed correctly,
the stamped number is on the
camshaft side of the engine.
-Tom
1950 Chevy 3100 w/ 1956 235
