| | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | How do I know if I have to down-shift going uphill?
Sorry if the question is dumb. I have a poker run on Saturday and there is a fairly steep valley on the route. I "threw a rod" on this hill 2 or 3 years ago, and I think maybe the engine was lugging up the hill. So would someone please explain to me how and when down-shifting is done going uphill. Do I just shift into second if the RPMs drop too low and then take it slow?
Thanks. I don't want to wreck another engine. The other engine was low on oil, so of course that didn't help. This time I'm going to stop at the bottom of the valley and check the oil.
The truck is a '52 with a 216 and a 4:11 rear. The tires are 215/85/16. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Once you start loosing power, down shift and get the RPM's back up...if the power drops again, down shift to 1st gear and crawl up the hill. It's a feel thing, don't lug the engine... Mike B  | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | You can usually tell if it's lugging too hard or straining a lot. Then just drop to the next lower gear and proceed to the top. It should pull easier in the lower gear and not have to work as hard. That being said, don't over rev it then either. You should also be able to tell if it's over revving or winding too tight. If you've driven the truck a lot you should have a feel for it and be able to tell where it's "comfortable". Hope that made sense. | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Good, it's clear, thanks. It seems to me there's a bit of a trick to it. It maybe needs a little gas so it will shift smoothly? | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Good, it's clear, thanks. It seems to me there's a bit of a trick to it. It maybe needs a little gas so it will shift smoothly? Yes. When you go from third to second, you need to get increase the engine RMP to where it would be if already in second. Same when going from second to first. Like Mike said, it's a touchy/feely kinda thing. You'll get the hang of it.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Your bad luck with your old engine just has you gun shy. All engines ultimately die of old age. These high torque engines were designed to do a lot of work under horrible conditions. If your current engine is in good repair, drive it as it was intended to be driven. Hard. (Within reason of course.) Carl
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | It made it up the hill without exploding. And I didn't downshift because I really didn't feel like it needed it.
But it got very hot towards the top of the hill, the needle really climbed and approached 210. So I pulled over and let it cool down for 15 minutes. Maybe I need to have the rad re-cored. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | There are hills in Saskatchewan?
I lived there four years; the joke was that prisoners could never break out of jail because it was so flat that three days later the cops could still see them on the horizon.
1951 Chevy Panel Truck
| | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Actually, not saying the radiator doesn’t need refreshing but downshifting and getting the rpm into the mid 2,000 range can help by speeding up the fan, moving more air through the radaitor. And you’re not lugging the engine. Proper shifting makes for a happy truck!
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Nov 2012 Posts: 256 Haunting the SBP since 2001 | | Haunting the SBP since 2001 Joined: Nov 2012 Posts: 256 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It would always be good to find a quiet, gentle hill to practice up and down shifting on.
If your water get hot in your truck, turn the heater fan on for the few moments it takes to get to the top of the hill.
Ed
