9 members (Cosmo, VicZ, Patina 54, Wally / Montana, Mike Burns, Ponchogl, HandyAndy, 2 invisible), 191 guests, and 0 robots.
Topics128,087
Posts1,055,977
Members48,430
#1266635 05/22/2018 4:41 PM
Custom Title
Custom Title
I have a few questions about weatherstripping on my '49. The truck was a total basket case when I got it so I'm not sure how some of it is supposed to go together. Anyway, on the outside of the door glass, there's supposed to be a rubber "wiper" that fits in a groove inside the door. I see the groove, but what keeps the strip of rubber in place?
Along the bottom edge of the interior of the door there is a metal strip attached with screws that looks like it would secure some weatherstrip. What goes here?
Last, how does the wide strip of rubber between the bottom of the cab and running board attach to the truck?
Pics would be great! Thanks in advance!
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
The vindow glass wiper is v shaped at the bottom so it stays in the groove
...pic...
Bottom of door, door weather strip wraps here
Screws hold the rubber strip from cab to running board
...pic..
If you scroll down on my link for my 52 panel I have a couple good pics showing the weather stripping on my 52 door of the strip on the bottom of the door. I think yours and mine are the same....is this it?
https://lh3.googleusercontent.com/-...ivi2MhzWrnTVHM-qv9xlWyGMal=w1121-h840-no
https://photos.google.com/share/AF1...aGF4VC1GRDBKSHFxLUgtMXdGUjh0MDVDR0E4YzNn
Custom Title
Custom Title
Ok, that solves the door bottom question.
I'm still unsure about the other two..
I don't see how the groove in the door holds the wiper. The "fat" side of the wiper rubber I have just fits loosely into the groove in the door..
Would it be possible to get a better angle of the cab to runningboard rubber?
49 Chevy 3600
65 Chevy K10
Southtowns, I thought I had my pictures of the cab to running board in the album but obviously not. I will find them and load them tonight.
...in the meantime the body "rolls under" and there is a horizontal "lip" that the rubber lays on and is bolted to it. I THINK there is another metal strip that lays on top to keep the bolts/screws from pulling through the rubber. Worst case is I'll have to get under the panel and take some more pics...........its been a while since I did them.
classic parts forum
...link....
Custom Title
Custom Title
Aha! I'm missing the piece of flatbar that goes with the cab to runningboard rubber. Anyone know where I can get those?
49 Chevy 3600
65 Chevy K10
It''s just flat sheetmetal. You could get that at a local sheetmetal shop. Or you can order them from Jim Carter. Part # CB136
If you can view the pictures in photobucket...click on "pictures in my photobucket" here below my name and go to page 9 where you can see a couple of pictures with mine installed.
(I hadn't found where I put them originally or lost them a while back in a computer crash) Trying to get all photos moved from photobucket but haven't yet.
Both those links are the same, Alvin
And it is quite helpful to this discussion
direct link to the photo (maybe):
http://oi140.photobucket.com/albums/r19/LutherParris/52Panel/000_0277-1.jpg
Thanks Tim, there was one other pic I was trying to link to but got the same one twice......I'm doing several things at one time here!
Still, the one that I posted is the best of the two for him to look at.
I have 279 pictures of the panel resto in my photobucket and only was able to get out about 2/3 of them before they practically shut me down.
I'm still trying to retrieve them, be it one at a time, as I "lost" the original ones I had "saved". Oh well, we'll keep trucking...and thanks to you Tim for all you do to keep us going straight.
Awww, I think this is the other one.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0276-1.jpg
No problen, Alvin
Even your one photo was quite helpful.
Best Regards and Good Wishes,
Custom Title
Custom Title
Thanks for the pics, that one makes sense now.
So I'm just stuck on the door glass wiper/seal. Anyone have pics of those being installed? It's like the groove in my door is too wide and won't hold the rubber
49 Chevy 3600
65 Chevy K10
Classic parts forum
...link...
Maybe you have to wrong wiper material?
Custom Title
Custom Title
Hmmm.. I want to say my doors don't look like that for some reason. Unfortunately it's going to be awhile before I get a chance to look at them. I got back on my ship last week...
49 Chevy 3600
65 Chevy K10
That example has the wing window. Your 49 is solid. But wiper should be same.
I was going through the assembly manual......
Big X2
