| | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2018 Posts: 35 | A little background. Purchased used, but refreshed motor. Top end was done, bottom end was done, with the exception that I swapped out the cam to a 261 mechanical. The gears teeth where they mated were marked by the person that made the motor. I had a machine shop swap the gear on the cam for me and re-installed in the same position. (I didn't check the alignment marks, but sure wish I did now).
The #1 piston was TDC when I put on the head, assuming its on the compression stroke.
I was following this routine, with #1 valve at the front of the motor: TDC #1, adjust 1, 2, 3, 5, 7, 9 Rotate crank 360 degrees, adjust 4, 8, 10, 11, 12
As my title says, valves 1, 2, 3, 5 were off the lobe and adjusted no problem. However, the push-rod on 7 was extended and I scratched my head and stopped for the night.
Laying in bed, a few scenarios ran through my head.
#1 The motor is actually TDC #1 on a compression stroke. #2 The cam is not timed correctly to the crank. #3 The lifter is stuck in its bore.
Is my routine flawed? Any other options than the 3 above? What do you think the issue is?
A Ford guy trying to help a buddy with his dream truck
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Maybe different length(s) of that push rod and/or lifter? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Before speculating further... first check #1 and #3 , they're easy questions to answer. What do you find?
| | | | | Joined: Apr 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2018 Posts: 35 | Before speculating further... first check #1 and #3 , they're easy questions to answer. What do you find? Both push rods are down, which I get will kill #1.
| | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | When coming up to TDC on #1 watch the rockers on cylinder #6, exhaust should be closing & intake opening if #1 is on compression stroke. Most folks I know refer to the pushrods / rocker as cylinder #x, intake & exhaust rather than 1 - 12 down the line.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Hotrod Lincoln posted an excellent way to adjust valves. Using his method you will see every valve/rocker arm moving.
Post back and let us know if it helped solved your problem.
Listed below is a copy & paste of his post. ------------------------------------------------------------------------
Companion cylinders are: 1&6, 2&5, and 3&4. These pistons reach top dead center at the same time, one on the compression stroke with both valves closed (ready to adjust)
and the companion cylinder is at the top of the exhaust stroke with the exhaust valve closing and the intake just beginning to open.
This condition. with the valves moving in opposite directions, is called "rocking".
Let's get ready to adjust the valves on the #1 cylinder- - - - -
Turn the crankshaft clockwise, and watch the rocker arms and valve springs on the #6 cylinder.
The last rocker at the firewall (#6 exhaust) will begin to compress the valve spring, causing the valve to open. Keep turning. The exhaust valve will open fully and begin to close- - - the spring will relax. Keep turning. Just as the exhaust valve reaches the closed position, the second rocker from the rear (#6 intake) will begin to move. Stop turning.
Go to #1 cylinder and adjust both valves. They will both be fully closed, with the piston at top dead center.
Continue turning the crankshaft and watch the valves on #2 cylinder as they assume the "rocking" position. This will happen 1/3 of a turn of the crankshaft after #6. Adjust both valves #5.
Turn again until #4 rocks - -adjust both valves #3.
Rock #1 - -adjust both valves #6. Rock #5 - -adjust both valves #2. Rock #3 - -adjust both valves #4.
On a hydraulic lifter engine wait 15 minutes before starting to allow all the lifters to bleed down to their normal running position.
A mechanical lifter engine can be adjusted the same way with no time delay before starting.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Apr 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2018 Posts: 35 | Thank you all for the responses. Tom, you're the man. I've printed it out and will follow it to a tee.
Ken
| | | | | Joined: Apr 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2018 Posts: 35 | I pulled the balancer and cam cover off and could not find any timing marks on the cam gear. However, I did put it back, the way I took it apart. What I found was the mark the prior owner put on the gear made the cam TDC for #6, 180 degrees out from TDC #1. Once I figured that out, all was good and set the initial rocker gaps.
