| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Guys, I've searched and searched to no avail for a 5/8-11 Female to M10 Male adaptor fitting for an angle grinder. Some of you guys are pros at finding these on the web. I could not. If all else fails, I did find a 5/8-11 female to M14 Male adaptor that I'll just grind down and rethread to M10. Purpose will not justify having one made at a machine shop. THIS IS FOR LOW SPEED APPLICATION. Appreciate the help fellas.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | You should find one here: AdapterHarold
Harold Is a restoration ever finished? | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Allen,
Most any Ace Hardware should have exactly what you're looking for, #27921. Weiler makes them. I think Makita was one of the last ones to use the M10 shaft on their angle grinders, still some of those grinders out there also. Most everybody now makes theirs with the 5/8-11. The grinding wheel/wire wheel industry made that happen.
Mike
1951 3100 5 window
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Thanks Harold, Google was my first stop.....still can't find one....
Mike, so I need the opposite of that fitting. That one allows you to use a 5/8 attachment on a grinder with a M10 arbor. I want to use an M10 attachment on a grinder with a 5/8 arbor. I don't think they are made, probably for safety reasons. I'm gonna have to red neck it..... Thanks for input
| | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | I read it backwards.
But you are probably correct. Going the route you want to go is going to extend whatever you use too far out.
However, I see guys taking the guard off a 4-1/2" angle grinder so they can use 6" cutoff wheels.Too close for me.
Mike
1951 3100 5 window
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Problem solved. I just welded a 5/8-11 nut to a 10M-1.25 bolt. A little touchy to get lined up but works like a champ.
