3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#1265985 05/15/2018 3:36 PM
So in my search on repairing or replacing the axle shafts on my '53, I came across Tom Differentials' website and see that he makes 30 splines axles that will work with open 12 bolt spider gears. I've tried contacting him with no luck yet, so does anyone know if it's as simple as getting 30 splines axles made and simply swapping out the spider gears? Tom's website mentions being able to ditch the cross pin block, but I'm not sure how. Tom's axles appear to be the wrong length for my year, but Dutchman Axles would be able to make some. Pricey, but it's at least an option if a repair or used axles don't pan out.
Thanks in advance!
1953 Canadian GMC 9314 w/ (factory) Chevy 235
' Offline
Tom Watt passed away a few month's ago . His business is for sale .
So , I doubt you'll be hearing from him .
'54 3600
1954 3600
Now cruising in
The Passing Lane
Ahh, I saw it was for sale. Thanks for the info
Would anyone have some 12 bolt spider gears kicking around to measurement so I can compare to stock? I’ve tried emailing a couple vendors for measurements with no luck.
