1 members (Otto Skorzeny), 81 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1265704 05/13/2018 3:26 PM
The fact that I am asking this question probably means that I have no business using a lift. But here goes: I gave myself a used two post lift for Christmas and now in May I am lifting my '53 truck for the first time. The bottom of the frame is a good six inches above the height of the running boards and the lift points are too close to the legs to lift on the frame. What is the safest way to place the legs of the lift under the frame? All my ideas seem dangerous. There must be a simple solution. Pictures would be appreciated
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Leo Offline
Moderator
Moderator
Hi Karl, I too have a 2 post lift and a 1953 3100. The lift arms of my hoist are telescopic, are yours? For me, the lift points on the truck are quite high so I need to put on the 6" lift extensions. It is not ideal but it works quite safely.
Leo #1265707 05/13/2018 4:12 PM
Well the arms are horizontally telescopic, on the ends of the arms are pads on threaded shafts one can rotate upwards. They max out at about 3 inches. I suppose the safe solution is to invest in longer extensions (or whatever can be properly attached to the ends of the arms).
1953 Chevy 3100
1960 Volvo PV 544
The safe way to do it is to, as you have guessed, buy yourself a set of longer extensions. Just make sure you lift from a level spot on the frame. Don’t just stack 2X4 or 4X4 on top of your lift arms. That is a hospital trip waiting to happen.🛠
I've been hoping for some sort of MacGyver solution, maybe using a vacuum cleaner and three burned out light bulbs. Where are the answers from the corner-cutters?
1953 Chevy 3100
1960 Volvo PV 544
You might be able to have a local welding shop fabricate H-shaped steel extension boxes that would slip over the frame rails and give you a steady point for the lift arms to engage. They don't have to be made of thick metal, probably 4MM thick steel would be plenty strong for a properly designed extender 6 inches tall or so. Let the legs of the extension extend a couple of inches over the sides of the frame rail for stability.
I'll look into that, Jerry. I do believe that there are longer extensions on the market. I'll look into the prices. We have a good welding shop here in the village but I would be surprised if they can produce anything cheaper then those extension (made in ???). Thanks for the input, guys.
1953 Chevy 3100
1960 Volvo PV 544
Since I do virtually all my own fabrication of things like that, I have a habit of forgetting to factor in labor cost when I consider an option other than just buying a factory part.
If only I could fabricate such parts from wood...
1953 Chevy 3100
1960 Volvo PV 544
Rock Maple, maybe?
LOL!
Sir Searchalot
Sir Searchalot
They are all dead.
Welding rock maple is a challenge.
1953 Chevy 3100
1960 Volvo PV 544
Faced with your problem, I cut 6'' blocks of wood and using a fostner bit bored holes the same size as the acme threads. I then turned the end plates up side down and screwed them all the way through the extension arm. This exposed about 3'' of threads which fit into the holes holding the blocks firmly.... Well, you did ask for a redneck fix.
I have found a local source for extensions. I like fashioning my own parts but my wife gets terribly nervous everytime I say "I made it myself." I wonder why that is?
1953 Chevy 3100
1960 Volvo PV 544
Just use a hardwood dowel rod and lots of amperage. Have a buddy stand by with a good fire extinguisher!
LOL!
JB WELD? grin
On my Rotary two post lift the arms have a short and long flip up lifting pad which covers most needs but on early cars with the tall running board splash aprons we had to make up taller pads to reach the frame. Our model has a pivot pin on the pad that runs through the arm and is held in place with a snap ring. IIRC the pin has about a 7/8 diameter so we just welded that size pin to a steel box that drops into the factory hole in the arm. We often have to jack up with a floor jack to get the taller stands under the running boards and again to get them off but it is safe.
Evan
When I bought my lift I bought 3" and 6" extensions with it. They interlock under the adjustable ones that are on the arms. That gives me a height of 6" and 9". I don't remember the price but they were not much. They are kind of important. I wouldn't mess around with fabbing something up and hope it works, but that's just me.
Originally Posted by bartamos
They are all dead.
Amazingly, there seems to be an endless supply of replacements:
My 2 cents: Given the investment in the truck so far, and then buying a lift, it seems to me a few hundred extra bucks for the correct extensions is well worth the expense. There are way too many stories with sad endings to take a chance with a back yard engineered work around.
Back yard engineered work around? You just described the very essence of hot rodding. That's what we do - V8's in vehicles that were intended to have 4-bangers, different suspensions, modified parts, etc etc. Back yard engineering is why our old cars are still running, any many of them running much better and faster than they were ever designed to run. Home builders addressing deficiencies in parts and products is how new parts and products are discovered and developed. Sorry, but I think any car nut worth his welder can make a part more perfectly suited for a particular purpose than some distant manufacturer who never actually uses his own product ever could. And probably do it much cheaper as well.
Organbuilder has found his solution. wave
