6 members (Jon G, tclederman, 52Carl, dt235sd, ShopRag, Bill Hanlon), 88 guests, and 4 robots.
Topics128,262
Posts1,058,331
Members48,485
Hey guys, I'm new around here. I have a 54 3100 that I just started a build journal for if you guys wanna go check it out. But I'm here with carb questions. The old fuel system had some heavy rust in the tank and lines. Truck ran fine but while replacing the tank and lines, I'm also replacing the fuel pump and rebuilding the carb. What I'm looking for is a recommendation for a good complete carb rebuild kit. Also, as you can see the stock fuel filter setup is no longer here, so I'm wondering what I need to set it back up the correct way. Thanks!
https://drive.google.com/open?id=1Am1thMlaMq1jCK8UaGDkWF11qXCUHXV9
https://drive.google.com/open?id=1ZVkPAoeTRKG0k16WBnYZFMDKDLef5org
https://drive.google.com/open?id=1f1Q3b7jlR4bhQ2TIMiD7RCJC2BYrfPma
https://drive.google.com/open?id=19sW4At7bhgSxk558DVFyzZM1DgSfL4uF
Number 45 stamped here
https://drive.google.com/open?id=1TZFQz-p-zz88n3SDkjMe4jHlgUI8s00o
And 4468 on the base here
https://drive.google.com/open?id=1InxmPqwTWvxaICxPx3J3vLKJ0wubw8gu
Also does the return spring setup look correct on this?
https://drive.google.com/open?id=1IAZuKa4SQuJHyqY4cGhJZyVm9G1P0CHe
When the truck wasn't running the gas pedal would stick down, I'm wondering if the return spring isn't correct or if I need a new one. I appreciate any and all help, thanks in advance!
The spring install is not quite correct but an easy fix.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0099.htm
This is a parts catelog listing for the carbs, might be helpful.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0289.htm
Mike
Carburetion specialist
When referring to carburetor kits, the word "complete" has different "meanings" to different individuals.
We can furnish a major overhaul kit (CS-330); and will be happy to discuss the entire contents of the kit if you call. That way you can determine if your "complete" and my "major" are compatible.
573-392-7378 (9-4 Mon-Tues central time).
Jon.
The Carburetor Shop
https://www.ecklersearlychevy.com/chevy-carburetor-rebuild-kit-rochester-bc-1949-1954.html
I ordered this kit here, looks pretty complete. The truck was running good before I took the carb off so I don't suspect anything major being wrong with it.... hopefully!
Does your accelerator pump look like the one in the kit you ordered?
The pic is blurry. Can't see if it the "stem" is flat or round.
Also make sure your air horn gasket is correct.
Other accelerator pump & 2 different air horn gaskets
-Tom
1950 Chevy 3100 w/ 1956 235
