| | | Forums66 Topics128,258 Posts1,058,329 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 |
Mike
| | | | | Joined: Nov 2002 Posts: 2,783 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,783 | When referring to carburetor kits, the word "complete" has different "meanings" to different individuals.
We can furnish a major overhaul kit (CS-330); and will be happy to discuss the entire contents of the kit if you call. That way you can determine if your "complete" and my "major" are compatible.
573-392-7378 (9-4 Mon-Tues central time).
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Does your accelerator pump look like the one in the kit you ordered? The pic is blurry. Can't see if it the "stem" is flat or round. Also make sure your air horn gasket is correct. Other accelerator pump & 2 different air horn gaskets
-Tom
1950 Chevy 3100 w/ 1956 235
