6 members (delky, Otto Skorzeny, UtahYork, mason86, Bill Hanlon, Woodcmiami), 54 guests, and 2 robots.
Topics128,030
Posts1,055,424
Members48,422
#1264801 05/05/2018 12:27 PM
I just converted my 56 chevy pickup to disc brake conversion from CPP. The problem I have is the front passenger side caliper locks up when pedal is depressed and wheel will not turn when I let off the pedal. Do I need a proportioning valve?
You do need a proportioning valve in the system ..........but not to solve your current problem.
Will not turn when you let off the pedal..........sounds like pressure is being trapped or held in the caliper or mechanical binding.
Brake master not returning completely after application would cause caliper lock.
Did you install pressure check valves in the caliper lines ?
Trucknut,
I would check a couple things, Order doesn’t matter. How is the brake peddle return spring? Check linkage for binding and correct setting (peddle to master cylinder linkage might be too tight) Double check brackets that hold your disk brake caliper. (Mine was not true and I had similar issues with cpp conversion kit.) consider rebleeding your system. You should have portioning valve if you are running disk (front) and drum (back) set up.
Just a few thoughts after having a similar issue.
Chris
H Online: Content
If only one wheel is locking the problem is in the caliper or the flex line going to that side. Try loosening the bleeder screw to the locked-up brake and see if it releases. If so, replace the flex line. If not, replace the caliper. "New" doesn't always mean "good".
Any more these days, 50% chance of being "good" is becoming the new normal.
Hey ndkid275 what did you do to fix the problem you had with cpp mounting?
