9 members (Oswald, Bill Hanlon, Rosco, Southerntruck, Bungeemaster, 2-Ton, Pre '68 Dave, TUTS 59, 1 invisible),
253
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,288 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Hello, my 57-3100 looks to have the original fuel sending unit and dash gauge for fuel. The gauge has always jumped around quite a bit while I’m driving, at least 1/4 tank amount on the gauge when running, meaning when it’s full it jumps from 3/4 to full. It seems to do that throughout the cycle from full to empty, although empty is before the dot for empty. I purchased a new sending unit to have on hand when I remove the one in the gas tank, but I also be thinking about the Guage? Your thoughts are appreciated! Kevin
Thanks, keep truckin!
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | If you have a stock tank,it won't have baffles in it. The gauge moving while driving is quite normal in my truck. | | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Wow, hadn’t thought of that, I do hear swishing from time to time so maybe no baffles are in there, I’ll check when I open it up, thanks,kevin
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | If you know how, hysteresis can be added to you fuel gauge to slow down the movement of the needle. This would take place at the gauge itself and is pretty simple with a little math or ‘seat of your pants’ on the work bench using capacitors.
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | When my needle stops jumping around, I know that I have 2 gallons left and I need get ready to call someone to bring me gas because I will forget to stop for gas because I am stupid like that...
