0 members (), 124 guests, and 1 robot.
Topics128,157
Posts1,056,876
Members48,458
In November 2016 I got a 49-3100--it is almost finished. If my Wife ever knew....It was full of nests and droppings. There was even a nest in the old headliner. Did all the vacuuming at the PO's home, so she never knew. The solution is buy liquid peppermint at health food store, put in a cotton ball and wrap in tinfoil. I have done this for the woodpile, shelves in Garage and under the front seat of all vehicles. no more rodents...
This topic comes up every so often. Another solution for putting your truck in storage for awhile, cut slices of Irish Spring soap bars and put them in all the nooks and crannies. For those of you vacuuming rat/mouse droppings out of your barn finds, be sure to use, at the very minimum, a dust mask. The Hantavirus is nothing to make light of.🛠
Also, put the "repellent" in lower rear cab corners (after cleaning them out and clearing the weep hole in each side).
Fox Offline
My big bad kitty does a pretty good job! 😃
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I had read somewhere, maybe on this site, that Bounce dryer sheets would repel rodents. I put them in all the drawers in my tool boxes and the mice loved them. They shredded them up for nesting material.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
They love Irish Spring also. I've got bars with teeth marks on them to prove it.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Fox Offline
My kitty doesn’t have mice bites! 😜 hehehe!
I’ve tried soap, steel wool, etc but those little buggers kept coming. Cats work but then you have cats. A tough compromise for some, but not too bad if you heed Bob Barker’s advice.😉
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
I've heard that moth balls work.
Last edited by Justhorsenround; 04/27/2018 1:24 PM. Reason: Inappropriate comment for family friendly site.
I use lots of traps baited with peanut butter. Catch mice and moles.
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
I have used moth balls. In the Spring/Summer (after truck hibernation), remove the math ball and put the truck outside on a few hot/warm days (with windows closed) - air out after a few hot hours, each day.
Any areas that they could possibly get into the cab I used epoxy and steel screen to cover the openings. Under the floor mats, under the seat, inside the cowl openings, etc. Haven't had a problem since.
Rick
1939 Chevrolet Stake Truck
I've caught dozens of mice with bucket traps. I keep one in the shed to keep them out of the tractors and other garden machines. One in the garage and one in the attic. If they are placed in an area that gets cold in the winter I put a little antifreeze in to keep the water from freezing.If you are not familiar with these google "bucket mouse traps". They work great. I've caught close to 2 dozen mice with out having to rebait at times.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
I use live traps, then I turn them loose at people's houses I don't like ;-)
