2 members (fonz8261, HandyAndy),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,176 Posts1,057,058 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | I ordered the water pump conversion the engine I'm going to put in my 1946 Chevrolet truck. I have read where people have drill the end of there crankshaft for a small block bolt. But I am planning on using a balancer off of a 216 with the hand crank teeth so I guess that means I can't use a balancer bolt? Also it says to use sealer on the adapter to block surface what kind of sealer is used red, black or grey? | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | The 216 balancer can be modified to accept a center bolt by boring a step into the front of the hand crank lugs in a lathe. The hand crank can't be used then, however.
| | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | What kind of sealer is used? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have used almost every color of RTV, and they all seem to work fine.
See the USA in your vintage Chevrolet! My Blog | | |
