1 members (Peggy M), 304 guests, and 4 robots.
Topics128,159
Posts1,057,033
Members48,460
I ordered the water pump conversion the engine I'm going to put in my 1946 Chevrolet truck. I have read where people have drill the end of there crankshaft for a small block bolt. But I am planning on using a balancer off of a 216 with the hand crank teeth so I guess that means I can't use a balancer bolt? Also it says to use sealer on the adapter to block surface what kind of sealer is used red, black or grey?
H Online: Content
The 216 balancer can be modified to accept a center bolt by boring a step into the front of the hand crank lugs in a lathe. The hand crank can't be used then, however.
What kind of sealer is used?
I have used almost every color of RTV, and they all seem to work fine.
My Blog
