2 members (Rusty Rod, porsche), 64 guests, and 3 robots.
Topics128,021
Posts1,055,357
Members48,420
Does anyone know a source to get the small wire springs ( apx 3" Long 1/4 " diameter) which are in crisis cross pattern holding coil springs tops in task force series truck seats and back. Thankyou
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Sir Searchalot
Sir Searchalot
http://www.diyupholsterysupply.com/...tBy=&Category_Code=upholstery-spring
It is just an extension spring probably sold at most hardware stores. Just find the correct length and spring rate.... or buy on line in quantity. Springs with the same OD, length and wire diameter will have approximately the same spring rate as yours. Nothing too technical for those springs.
There are a couple of upholstery tips in the TIP SECTION/interiors
Thank you.
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Good information
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
Moderated by  ndkid275, Phak1
