Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (MickeyP, Gdads51, Otto Skorzeny, Bill Hanlon), 48 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
Is there any trick to separating the old outer cowl panel from the upper panel by the windshield and the firewall itself? Finding the various spot welds is proving almost impossible as they are invisible. Down the door front hinge panel was easy as they were visible.
I know the cowl panel slips up and behind the upper panel but it also appears I need to coax the upper panel into bending out a little to allow the new panel in.
Paul
1951 3100 5-window
with a '55 235/floor mounted 3-speed
Some of the story in ODSS
Most of it in The Shops Area wink
I believe the upper cowl to lower cowl panel joint is recessed and leaded, so you need to melt the lead out to find the spot welds. I think I would modify the patch panel to fit instead of bending the original upper cowl.
That's the case if you got the full lower cowl panel patch. If you got the lower half of the lower cowl panel (doesn't go up to the hood), then just cut the original out and butt weld the new one to the remaining metal.
I just did mine. Melt the lead. Find the spot welds, drill them out.
See the job here, start at the bottom of the page. http://www.bunchobikes.com/1952suburban18.htm
Many thanks guys, worked like a charm.
1951 3100 5-window
