8 members (Otto Skorzeny, Bill Marlow, HandyAndy, GRNHydra, 49nut, Wally / Montana, cmayna, 1 invisible),
256
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | I'm ready to choose a floor shift for my 54 3100 with a bench seat and 350 TH automatic. The Lokar units look well made to me. Still need to decide on the height and shape of the shifter handle. Of course I want it to miss the dash and seat and be within a comfortable reach. What works for you? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Used a Lokar Nostalgia 17" in my old '37 Olds Streetrod. Lokar is quality stuff but you pay for the quality.
| | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | I have a Lokar shifter for my T350, I believe it's the 16" long lever. I started with the 23" long and then went to the shorter lever. The shifter works good, only complaint is the cable inside that moves with the push button rattles all the time. Being a trans mounted shifter, the vibrations from the motor come up through the shifter and shake it around. If I could, I would switch to floor mount. Even a smooth running engine will cause the long shift lever to vibrate and rattle. Locker suggested some thick grease in on the cable, it helped for a while, now I just steady it with a light pressure while driving. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Good morning redwing.
I've had Lokar trans mount floor shifters in my '32 Ford roadster street rod with both the previous TH 350 trans and the present 200 4R. Both of those shifters are, in my opinion, very high quality that one rarely sees anymore in this era of crap from China. I opted for short shift handles, unlike the longer handles that Joe used. That may be the reason that I had absolutely no problems with noise or vibration of the lever.
As others point out Lokar parts are expensive but quality usually is.
A buddy of mine was an automotive professional and he was once at a trade show where Lokar had a booth. Some Chinese were there photographing the Lokar stuff so they could make bootleg copies and the Lokar crew had to call security to have the Chinese ejected. It's said that "Imitation is the sincerest form of flattery".
Ray
