3 members (klhansen, 3800GUY, 1 invisible), 63 guests, and 3 robots.
Topics128,153
Posts1,056,847
Members48,456
#1255558 02/19/2018 4:00 PM
Hello Bolters
I live in Lakewood, a foothills suburb of Denver.
I have owned these trucks -
1959 Chevy 1/2 ton pickup
1956 GMC 3/4 Dubl-Duti Step Van Delivery
1954 Chevy 1 ton long bed pickup
And currently own these guys -
1946 Chevy 1.5 ton truck
1950 Chevy 2 ton cabover
-Scott Mourer
welcome to our quiet corner of the 'Bolt.
Another quality post.
Real Trucks Rattle
Thank you.
I'm in Cheyenne, WY and I need a good mechanic to help stop a major squeak in the engine compartment of my 1953. I can trailer to wherever it needs to go. I cant seem to find where it is coming from or what to do to fix it. Help!
thx: Kldob
Is the squeak constant? high pitched? does it vary with RPM?
Are any of the pulleys loose? can you wiggle any of them when the engine is OFF!!
I would use a belt conditioner to rule out the belt.
If you have a long screw driver, you can carefully place the tip of the screwdriver on the generator/alternator, valve cover ect. put your ear on the handle end and listen. (be careful around moving parts)
Real Trucks Rattle
KLdob, did you get this figured out?
Real Trucks Rattle
A while back I posted about a squeak in the engine that increased with rpms. I found it! it turns out that the person that replaced the okie bearing dented the flywheel inspection into the flywheel. I would have never guessed it. It sounded like a dry bearing.
anyway it is fixed now.
Keith
Moderated by  69Cuda, Fibonachu
