3 members (TUTS 59, WICruiser, 1 invisible), 125 guests, and 3 robots.
Topics128,090
Posts1,056,382
Members48,442
#1261598 04/05/2018 3:57 PM
Was playing around with my 261. I just picked it up from a buddy on a trade a while back. I noticed the manifold bolts are sawed off. The front one taped out with some help from a hammer. The back one is very tight . Been a few days with deep creep soaking but nothing yet. Question . Would these have been threaded from factory ? If so i will be drilling it out i guess. Thanks
The front and rear ones are not bolts. They are threaded alignment pins. Pretty much a sawed off bolt. You don't need to remove them.
X2
Mike
Sorry for the confusion. Wrong end of the manifold. The end the exhaust pipe flange fits and bolts to. Seems to me they maybe threaded but i can't seem to recall. At least one has been drilled maybe by the p/o and i have the bolt out. The other bolt is either threaded or rusted in tighter than i have ever seen. And thats saying something. Thanks
There were threaded studs at the bottom/attachment opening on the exhaust manifold.
It one/both were drilled out you could use a hardened bolt that fits through the hole in the manifold.
Ok that makes sense. The one is drilled out already. And the other looks like i need to do the same. Thanks for the help guys. Keep on truckin...
