1 members (Eileen),
99
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | Was playing around with my 261. I just picked it up from a buddy on a trade a while back. I noticed the manifold bolts are sawed off. The front one taped out with some help from a hammer. The back one is very tight . Been a few days with deep creep soaking but nothing yet. Question . Would these have been threaded from factory ? If so i will be drilling it out i guess. Thanks | | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | The front and rear ones are not bolts. They are threaded alignment pins. Pretty much a sawed off bolt. You don't need to remove them.
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 |
Mike
| | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | Sorry for the confusion. Wrong end of the manifold. The end the exhaust pipe flange fits and bolts to. Seems to me they maybe threaded but i can't seem to recall. At least one has been drilled maybe by the p/o and i have the bolt out. The other bolt is either threaded or rusted in tighter than i have ever seen. And thats saying something. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There were threaded studs at the bottom/attachment opening on the exhaust manifold.
It one/both were drilled out you could use a hardened bolt that fits through the hole in the manifold. | | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | Ok that makes sense. The one is drilled out already. And the other looks like i need to do the same. Thanks for the help guys. Keep on truckin... | | |
