1 members (carbking),
144
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48252 07/26/2005 7:13 PM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | I have a 292 that I'm installing a clifford water jacket intake and four barrel carb on and I don't need all the holes in the stock 292 valve cover for the smog tube. Guess I should keep a pvc port but that's about all. What is a good substitute to use. I'll have to look again in my inliners, 12 port newz as I seem to remember that some one makes a valve cover adapter so maybe I can fit a (216 or) 235 plain cover on, NO chrome. The present ebay alum cover is costly, besides I don't need all that flash and I'll paint it anyway. Anybody got a spare non chrome 235 cover for sale
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#48253 07/26/2005 10:14 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have to have crankcase ventilation. You need a pcv valve in 1 opening & a vent either going to the air cleaner or a ventilated oil cap. Nothing from a 235 will fit the 292. They are 2 different families of engines.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48254 07/26/2005 11:32 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | WR Realizing that 292 covers are different than 216 and 235. That's why I mentioned the Inliners advertisement in 12 PORT NEWS http://www.merchantamerica.com/chevyhotrod6/index.php?ba=home They make an adapter (I do not see it on the web site so call) for chevy two stud 216 valve covers to fit on a seven screw 194, 215, 230, 250 &292 heads. From what I now know is Larrowe & Sons Truck Parts in Sandy, Oregon. It also appears from the advert picture you can fit this over roller rockers !!!! a shocking sleeper ?? but i'm still going to give them a call to be sure.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#48255 07/27/2005 2:21 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | speed way motors and Langdons both have Chrome sheet metal valve covers cheap. | | |
#48256 07/28/2005 3:47 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Landgon shows an adapter to place a 235 cover on the newer six. No picture online, but it is listed.
Fred 52 3600 69 C-10
#48257 07/29/2005 10:51 PM | Joined: Jul 2005 Posts: 5 Junior Member | | Junior Member Joined: Jul 2005 Posts: 5 | Langdon and Larrowe in Oregon both have adapters to use 4 bolt 235 covers on the later motors and I believe only Larrowe has one that works with the earlier 2 bolt versions.
Another option would be find a Mercruiser cover. It is a painted aluminum cover with a pcv hole and a twist on oil cap. They can sometimes be found on ebay. | | |
#48258 08/02/2005 2:57 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i called Lorrowe's (in oregon) and they are asking $225.00 for their adapter to fit a 216 cover on a 250- 292 model head.
. OUCH
#48259 08/02/2005 3:20 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | You can buy a new Offenhauser cast cover from Langdon for the same price as the adaptor. Cast cover quiets any valve noise and seals really well. I have a Clifford on my 292, the cover weighs about 10 lbs. compared to a few ounces for the sheet metal cover. | | |
#48260 08/02/2005 10:20 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I've been thinking of making an adapter to install an AD GMC valve cover on my 250 engine. More clearance for the roller rockers, and it would look cool.  | | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | I did a search and found this old thread because I remembered from years ago some/one of the vendors sold an adapter to put a 216 cover on a 230-292 engine. Might fool a novice, but no one with much Chevy 6-cylinder knowledge. Not considering the labor and expense it should be a good engine swap, and generally an improvement over a 216 or 235.
Professional Novice
| | | | | Joined: Sep 2016 Posts: 17 New Guy | | New Guy Joined: Sep 2016 Posts: 17 | i used an offenhauser cover , and you can have the sheet metal one for the shipping cost, but it may be cheaper to buy a new one | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Offering to buy, sell, barter or give away parts in the regular forums is prohibited. Sent a PM or post in the Freebie section of the Swap Meet. Thanks, The Stovebolt Staff.
| | | | | Joined: Sep 2016 Posts: 17 New Guy | | New Guy Joined: Sep 2016 Posts: 17 | | | |
