1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I have a minor problem with my carb, maybe only a link that came loose. BUT, in looking through some posts on the forum, I had some questions regarding the fir of the carb to my engine. I got my engine and carb as a package from a local shop, used, but had reason to believe that it was in good shape. I am having some reason to question that now, but that is another story.
The engine is a 1955 235 from an unknown application. I have it in a 46 truck with a 4 speed tranny (that is the way it came to me). The carb is a Rochester 1 bbl series B carb. It has an automatic choke. From what I have read, it sounds like that came from a passenger car. Is that correct? Do I have any issues? Is there a way to convert to manual choke (I am partial to manual). And is there a way to add the manual throttle (dash control).
Bob
BobS46
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That would be a Rochester BC carburetor (model B with automatic choke, C).
BC carburetors we used on some trucks from 1954 onwards, any maybe on earlier car 235s.
Does it have a post for the air cleaner, or, does the air cleaner clamp to the top/throat of the carburetor? | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks for the reply.
The air cleaner clamps on to the top of the carb. I am currently using the oil bath cleaner that came on the original truck.
Bob
BobS46
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bob,
What is the Engine Serial Number that should be pressed/stamped into the block on a ledge to the rear of the distributor? | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | 0161195 F55Z
the first number has the "1" digit indicated as roman numeral "I", but I suspect that they are "1".
BobS46
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes you can convert with one of these kits....or a DIY method using a remote throttle/choke cable from any FLAPS .
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 |
BobS46
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Be careful - different kits require the cable to be pushed or pulled. When in place important that position 1 (hot) is completely open, and position 2 (cold) is restricted by a clamp or sleeve to give you some idea of where you are when starting the engine. The choke pull-off for a manual transmission (what you should open the choke to immediately the engine starts) is something like 5/32" from completely closed (from the service manual setting for "automatic choke vacuum break"), which is what I mark the cable to. | | |
