| | | Forums66 Topics128,185 Posts1,057,274 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Seems all the catalogues sell them but who makes the heaviest dudy hood hinges for 1958-59? The truck I got has aftermarket ones whose metal is so soft the cog and key ar mutilating each other and jumping off track after a yr of use | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | For the most part, all of the vendors get their parts from the same source, there's not enough demand for different manufactures to tool up to make the same parts. Mike B  | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i went through this with the hinges for my 56. i ended up with a used set from eBay which work well. i agree the aftermarket ones were worthless | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Same here...I bought new repo hinges for my '56 3100 and my body man couldn't get the hood to fit right, so we reused the original hinges and the new springs. Mike B  | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thanks. That's been my experience too | | |
