4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#1259972 03/24/2018 4:33 PM
Hi there, I'm working on my 1950 GMC 228, and I can't figure out what the circled item is in the attached photo. It is on the block near the generator.
1950 GMC 150
Leo Offline
Moderator
Moderator
Looks like it could be the remains of an old block heater.
I've got the same thing on my 228. Still haven't figured out what it is. I don't think it's a block heater though. Mines a california truck.
Mine lived its whole life in North Idaho, so a heater makes sense. It still lives in a cold place but isn't used in winter ever. Can I remove it?
1950 GMC 150
If it's installed in place of a freeze plug, you should be able to replace it without any problems. The photo is a little fuzzy- - - -is the spring and the bracket below it attached to the part, or is that an optical illusion? Most block heaters will have an electric wire attached that would be plugged into an extension cord when the vehicle is parked overnight in sub-freezing temperatures. The cord might have been cut off flush with the heater but there should be enough of it remaining to see where it used to be.
This is only a guess - could it be some form of replacement for a leaking frost plug? Inset in hole, tighten to squeeze gasket and seal?
There are two designs of bolt-in freeze plugs. One uses a piece of rubber sandwiched between two flat washers and a bolt in the middle to expand it. The other design uses a copper disc with a wedge and a center boll. Both types are easier to install than the drive-in type with the engine in the vehicle.
K Online: Content
Could it be a pin that holds the throttle spring or clutch spring.Does it thread into the block .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Crusing in the Passing Lane
It looks like it is in the middle of a factory freeze plug. So, probably might be a good idea to remove it and install a new freeze plug.
Ed
It does thread into the block, and when I took it out it showed itself to have a six-inch metal rod. The remaining coolant in the block (the radiator is drained and the head is off at the machinist) poured out. It has two wires into what looks like an insulator of sort, broken apart, and the wires are cut. I will never use the truck in the winter, so I don't think any block heating is necessary. There is a similar looking plug further back on the block, but it is only threaded about 3/8 in. Wires on that are cut as well, and the throttle spring is attached to it.
1950 GMC 150
It's not useful unless your air temperature is below 180°.
That's pretty frequent, yes?
