2 members (49Chief, delky),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | hello has anyone had a Dana front axle narrowed and what the cost was ? i have a Dana 44 that would need to be narrowed 6 inches , also has anyone recomend wheel adapters for a 1.5 ton truck ? thank you 1pete1
| | | | | Joined: Oct 2017 Posts: 66 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 66 | Pete send me a pm.
Last edited by John Milliman; 03/25/2018 10:23 AM. Reason: buying and selling belongs in the Swapmeet
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A Dana 44 was used mostly in 1/2 ton trucks.
Dana 60 (also 70?) were under the front of 1 tons. The old 1.5 ton is more or less as capable as newer 1 ton.
All depends what you’re trying to do and what you expect, but I’d look at larger components for the larger truck. | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Sounds like an involved project. Would a newer 4wd frame be easier -- I know that presents new problems --sheet metal, cab mounts, steering. Or can you front half the frame? A 10 bolt 4wd ton - cab and chassis-- may be a candidate. I used a 14 bolt srw --then dualed it--- after moving the perches on the axle for a 46 3/4 ton.
I do like 4wds -- I have 3 ---soon to have 4 on a 59 GMC 1/2 ton but to my luck square body front axles (44's or 10 bolt) have a matched front spring perch width.
| | | | | Joined: Oct 2017 Posts: 66 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 66 | So Pete. The dana 44 was used by GM in the front of 1/2 and 3/4 ton trucks from 1960-1977. It came in a variety of configurations and is rated at 3300-3800 # . Just depends. So an adapter is no big issue. But... the ho110 ratio is a big deal. Basically if you want a 46 1-1/2 ton 4x4 you need to build a clone. That is use a 63-72 gm 3/4 ton leaf spring rear. Add a narrowed d44 3/4 ton up front. Uses 8 lug dual wheels from 73-2007. And be happy. You can use a variety of 14 bolts from 73 up. But more fabbing is required. If you wanted you could use 60-70 front drum brakes on any gm axle and not even change master cylinders. I could talk about how do do this for hours. Because I have done it a lot of different ways... | | |
