4 members (Guitplayer, MickeyP, Ponchogl, ShopRag), 90 guests, and 1 robot.
Topics128,035
Posts1,055,564
#125978 05/03/2007 1:16 PM
I have one of those problems that seems to be consistant with alot of you guys. I open the drivers side door and it falls about 3 inches or so...I took the striker off and put a come along on it from the inside and flushed it so it looks tight with the cab. I was thinking...could I weld the Hinge area? Would that work? The Adjustment screws just keep turning,they will not tighten up..kinda stripped. Has anyone ever done this (welded)..Thanks MIke G.
HURRY UP AND WAIT 55 235 3/4
#125979 05/03/2007 4:14 PM
Mike G. If I recall correctly I had a couple
hinge holes stripped also...What I did was buy new bolts, only a little longer, and installed lock washers and nuts...I certainly would stay away from welding...JMO Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#125980 05/04/2007 1:09 PM
hey...that sounds much better than welding...Thanks..
#125981 05/06/2007 7:21 PM
Mike,
What truck and year?
