| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 32 | Hello Folks. I have an old chevrolet truck the engine Number is KEA 375185 could some one tell me please is this a 235ci or a 216 engine.
Many thanks
Howard | | | | | Joined: Oct 2017 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 32 | Hello Tim
Many thanks for your help. I have taken out the pistons as engine was smoking alot, but no ware lip on the cylinders. But the bottom rings on the pistons were all stuck in, i guess this could be the cause of the smoke. There is no sizes on the pistons but they are cast. Can i take it that they would be standard. Thanks Howard | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Don't guess- - - - -measure. A standard bore 235 would have a 3 9/16" bore, 3.5625". Since the piston has a little clearance built into it, measuring the piston across the thrust faces 90 degrees from the wrist pin should give a measurement of around 3.561 or a bit less. Normal oversizes would be .020" over- - - -3.581, .030" oversize- - - -3.591, or 40 over, 3.601, etc. Jerry
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Since this has turned into a discussion of the internals, I’m going to move it to the Engine Shop.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hello, Howard,
Heed all advice from Hotrod Lincoln.
If you need to know how to make suggested measurements, ask here.
Good luck,
