1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1259583 03/21/2018 8:32 PM
Hello Folks. I have an old chevrolet truck the engine Number is KEA 375185 could some one tell me please is this a 235ci or a 216 engine.
Many thanks
Howard
Howardwade #1259585 03/21/2018 8:42 PM
Hello, Howard,
http://www.1954advance-design.com/chev-specs/1952-Chevrolet-t-ser.jpg
KEA - 1952 235 engine (assembled in Flint, Michigan) and first installed in a 6000 series USA Chevrolet truck
Howardwade #1259592 03/21/2018 10:03 PM
Hello Tim
Many thanks for your help. I have taken out the pistons as engine was smoking alot, but no ware lip on the cylinders. But the bottom rings on the pistons were all stuck in, i guess this could be the cause of the smoke. There is no sizes on the pistons but they are cast. Can i take it that they would be standard. Thanks Howard
Howardwade #1259593 03/21/2018 10:08 PM
H Online: Content
Don't guess- - - - -measure. A standard bore 235 would have a 3 9/16" bore, 3.5625". Since the piston has a little clearance built into it, measuring the piston across the thrust faces 90 degrees from the wrist pin should give a measurement of around 3.561 or a bit less. Normal oversizes would be .020" over- - - -3.581, .030" oversize- - - -3.591, or 40 over, 3.601, etc.
Howardwade #1259605 03/21/2018 10:56 PM
Since this has turned into a discussion of the internals, I’m going to move it to the Engine Shop.
Howardwade #1259626 03/22/2018 12:36 AM
Hello, Howard,
Heed all advice from Hotrod Lincoln.
If you need to know how to make suggested measurements, ask here.
Good luck,
