3 members (Otto Skorzeny, moparguy, DaveV), 112 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
#1259356 03/20/2018 1:44 PM
As soon as it warms up here in Iowa I'm going to roll the cab and chassis out into my home made (custom, ha,ha) spray booth and start painting.
Firewall was pre-sprayed before installing the cab onto the chassis.
My question is with the interior painted and the doors hung, how to you mask off around the perimeter of the door on the jamb to prevent
overspray.
Thank you
Jeff
Take the doors off.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Sounds like you and I are on the same time-line.
I painted the interior and door jambs a couple of months ago, and then re-hung the doors. The jambs I painted all the way out, beyond the latch strikes and beyond the hinges (to the outside of these if that makes sense). When you shut the door, provided your door has the weatherstrip on it, you will see very little of the jamb. on the sides and on the top and bottom. Weatherstrip covers most of the jamb. I did mask all the way around (masking the front jamb is fun with the door hung) all the way out as far as I had painted the jambs. But my truck is gonna be black, so I painted the jambs black. Shot two coats of primer on the exterior this last weekend, and no issues.
My logic is that the jambs should be the same color as the exterior color of the truck, so there isn't a contrast. Interior of my truck is a dark blue, and the windlace rubber separates the jamb from the interior, so you kind of have break there in the colors.
Mike
Mike
1951 3100 5 window
Mike
Thanks, I'm looking at this thread and it does have some great photos where the interior and exterior paints meet.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1235755/paint-at-door.html#Post1235755
